AKwiring said:Can someone please explain in simple terms how 240 works? Someone asked me and I found I could not give a clear explanation. Thank a lot.
I'll guess 847 posts. Closest without going over wins.peter d said:(Sorry, inside joke, let the games begin.)
electricalperson said:<deleted image file>
AK post #5 is a simple clear explanation of what is going on be careful because this question can open a big can of worms for example in the post Battle of the phases http://forums.mikeholt.com/showthread.php?t=96251&highlight=battle+phases Take note that it has been closed by the moderators so dont feel bad if you cant give a clear explanation you are not alone. It is most common in single phase and 3 phase delta systems.AKwiring said:Can someone please explain in simple terms how 240 works? Someone asked me and I found I could not give a clear explanation. Thank a lot.
Almost as simple as two 1.5 volt batteries in series.AKwiring said:Can someone please explain in simple terms how 240 works? Someone asked me and I found I could not give a clear explanation. Thank a lot.
480sparky said:It 'works' just like 120, 208, 277, 480 etc. It's just another voltage that's available, usually in single-phase services.
iwire said:Fair warning, no battle of the phase here. Stick with the OPs question or open a new thread. Thanks.
mivey said:I'll 4th that (#2). Plus the picture from #5.
This is too easy. Would you like to clarify your question so we can have more fun?
cadpoint said:Voltage add in parallel(often forgot)
crossman said:Let's get this on the way to 847...
Could you explain this further?
"Appears" is correct. The car "ground" is not really so much a ground as it is a return conductor. It is usually not tied to the "earth ground".jrannis said:Sometimes people think of AC power like a car battery with a positive and a negative and understand that current flow is from the "hot" to "ground" (we know better).
It appears to to explain the 120 volt circuits in a typical house.
Then we have this problem to explain how and where 240 comes from and where it goes now that the ground is not present.
Is this kinda of what you are asking AK?
