cm
- Pennsylvania
Re: How about this one !!!!!!
RULE #one if somone tells you the powers off go get a tester and check it for your selfe RULE#two assume the equipment is hot untill you are satisfied otherwise RULE # three make the ground then make the neutral first ,make the hot last Its not good to work on electrical equipment in a thunder storm either ,If all the above was forgotten or the inspector didnt know it and it was tagged energised and the lites were on and he is a stickler on chicken **** articles he probably dosent understand,maybee this was a wakeup call to him from above?
