randy_m
- San Antonio
- Electrical
I'm looking at a residential cove lighting project using some 24V LED strip lights and the following Class 2 power supply:
www.superbrightleds.com
Looking at NFPA 70 article 450 and 725, it seems like there are no enclosure or ventilation requirements given that the power supply will be a Class 2 power supply and clearly marked as such. Is this true, and can the power supply be mounted onto any surface without any concerns? I am aware that the input side of the power supply will need to be wired to line voltage inside a junction box.
If my understanding of the NEC is correct, why does the following Class 2 power supply have an enclosure box included?
This is my first LED low voltage project - thanks in advance for any help!
DiodeDrive 24 VDC LED Switching Power Supply - Enclosed Power Supply - Optional Power Cord - 60W / 100W
This DiodeDrive 24 VDC LED Switching Power Supply has been designed for constant voltage operation. Reliable and widely applicable, it powers LED technology without energy waste or risk of circuit overload. It is fully enclosed in a waterproof case.
DiodeDrive Dimmable LED Driver - Enclosed Power Supply - 12 VDC - 25W / 60W
This enclosed dimmable LED driver/power supply is class-2 rated and has a maximum load of 25 or 60 watts. The 12-volt constant voltage driver has 2 entry points to screw terminals for easy wire access and is encased in a durable, vented steel enclosure. The enclosure is equipped with wiring...
