Gilf
- Ankara, Turkey
Hi,
This is the first time i am designing such a panel, and i am very confused. The first section of the panel will be used to feed the fire pumps only hence it is a MLO panel and I will need to install the breaker on section 2 so that there is not a secondary OPDC between the source and fire pump panel. The two sections of the panel are connected with sub-feed lugs. How do I connect the main breaker on this sub-feed panel?
