Russs57
- Miami, Florida, USA
- Maintenance Engineer
My workplace wants to replace receptacle and switch cover plates in a Psych ward. They are concerned the patients might bend the nylon cover plates enough to gain access to electrocute themselves. Also some concern about them breaking the plate off and using it as a weapon.
So today I'm looking at something the boss has gotten as a sample from a salesman. From the enclosed literature it seems designed for just this type of use.
But get this. They want you to remove receptacle from box, fasten it to cover plate with two 8-32 tamper resistant screws and nyloc nuts. Then they want you to tap-con the oversize plate to the wall. This means neither the receptacle nor cover plate will be attached to junction box/mud ring in any manner.
Now I'm not a code guy but it seems to me either the receptacle, or cover, has to be screwed to the J-box.....right? Appreciate a code reference that I can wave under their nose because I'm thinking I'm not willing to do this.
BTW, walls are drywall and you know there isn’t going to be any backing to screw into.
