ivsenroute
- Florida
What do you see?
What is the circuit feeding? Might be ok.ivsenroute said:What do you see?
Ditto. :grin:chevyx92 said:What is the circuit feeding? Might be ok.
ivsenroute said:T
When would it be ok inside a residential structure to use 10awg NM cable fed from a 50amp breaker?
ivsenroute said:When would it be ok inside a residential structure to use 10awg NM cable fed from a 50amp breaker?
Certain motor loads such as the air conditioning condensing unit or a large air compressor.ivsenroute said:When would it be ok inside a residential structure to use 10awg NM cable fed from a 50amp breaker?
Not sure, but an air conditioning condensing unit would be one popular one.peter d said:Did anyone mention an air conditioner condensor yet?
ivsenroute said:Now a question:
Minuteman said:240.4(D) and (G)
Looks like shadow from the camera flash being higher than the lens.480sparky said:I gotta ask about the lower termination on the top breaker. To my old eyes, it looks like the aluminum is completely severed from the terminal. It could be a shadow, or a small piece of black tape, but I doubt it.
My guess it's more like some strands were cut off.
mdshunk said:I really didn't think that the black-red combination would be feeding the water heater. I'd have guessed a clothes dryer or a wall oven before I guessed a water heater.
peter d said:I've seen some guys run 3 conductor to A/C units for some reason, more than likely because it's all they had on the truck.
benaround said:Or for that 120v service recpt.
peter d said:No receptacle was installed...they just cut the white wire off and used the black and red.
