electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Last week had a client with a tripping breaker. Long story short, I isolated it between two receptacles, about 6 foot run, ramen in residential, studs, drywall. I reset the breaker and when I would touch the blacks together at the recep before the fault, the breaker would hold and there wasnt even the slightest visible spark on the wires, indicating no or very little current (didnt bother metering it). If I left he wires connected in several minutes it would trip again. One time I heard the fault in the wall, so it was definitely right there. Rogue nail? overdriven staple? Rodent damage? Anyway the question is what exactly is the mechanism that causes an intermittent fault? I have seen this quite a few times. There must be some sort of high resistance material that for some reason rapidly breaks down losing it dielectric capability, then the fault happens, causes a spark which forms more of the temporary primordial mystery substance. Is it carbon? How does this work?
