How do you calculate voltage drop?
I know there are voltage drop calculators but what's the math behind it?
The formula posted by Jim Shorts is the basic formula most often used. It's result is not highly accurate, and almost always higher than actual. All voltage drop formulas are based on Ohm's Law (E = I ? R) or the AC variation (E = I ? Z). The formula called the "exact voltage drop formula" by the IEEE is...
where cosθ is the power factor of the circuit. R and X (reactance) are determined using L and other parameters, such as the type of conduit.
Most "online type" voltage drop calculators use the basic formula.
Wow, no wonder calculators are popular.
