zappy said:A customer installed a attic fan and since he has a gas furnace up there it is recommended to use a lockout relay.Honestly don't think i've seen one before and i know i've never installed one before.Can you please help me out?Thank you for your help:smile:
stickboy1375 said:WHy on earth would someone turn a attic fan on with the heat running?
The manufactor's directions said that you could use a switch but is recommended to use a lockout relay.mdshunk said:If the thermostat is set properly on the attic fan, the lockout relay will be unnecessary. It won't run in the winter anyhow.
If you ask me, it's unnecessary in any event. The attic fan does not draw air from the house. It sucks in one gable vent (or soffit vent) and blows it out. Whoever suggested a lockout relay has just enough education to be dangerous. After all, we don't put lockout relays on the bath fans and range hood exhaust fans. Double retarded.
The manufacturer probably put that instruction in the event that you installed an asmospheric burner in an attic space. Not necessary for a basement or crawl space furnace. The lockout relay is pretty simple, if you're stil interested in putting one in. There's a Honeywell part that costs 12 dollars that would be perfect for that. Reply if you insist on putting one in, and I'll lay it out for you.zappy said:The manufactor's directions said that you could use a switch but is recommended to use a lockout relay.
zappy said:I dont know if its sealed combustion if it is then can the fan be on at the same time?Is condensing have like a drip pan or something to drain water?I saw something like that.
Yes i saw the things you described.peter d said:If it's sealed combustion it will have 2" or 3" PVC pipe (rather than a steel chimney) for intake air and exhaust. It does not have a drip pan to collect the condensate, but it does have a small trap and a 3/4" outlet connected to a PVC drain pipe.
It also said there may be times in the spring or fall when it may get hot enough in the attic to kick on the attic fan, and cold enough in the house to turn on the furnace.Well i was going to put a switch and then i brought this to the attention of the customer so now they want the lockout relay Maybe i can talk them back out of it:grin: Yes please marc can you guide me through it?You da man!Thank you.mdshunk said:The manufacturer probably put that instruction in the event that you installed an asmospheric burner in an attic space. Not necessary for a basement or crawl space furnace. The lockout relay is pretty simple, if you're stil interested in putting one in. There's a Honeywell part that costs 12 dollars that would be perfect for that. Reply if you insist on putting one in, and I'll lay it out for you.
stickboy1375 said:WHy on earth would someone turn a attic fan on with the heat running? Gotta love protecting the stupid... :roll:
Marc, where did you find this?mdshunk said:Great spirits have always encountered violent opposition from mediocre minds. The mediocre mind is incapable of understanding the man who refuses to bow blindly to conventional prejudices and chooses instead to express his opinions courageously and honestly.
I read... a lot! It was in a book I was reading at the time.LarryFine said:Marc, where did you find this?
I believe the opposite is the goal: no fan with the furnace operating. A 24v relay with an NC contact in series with the fan's power would do it.electricalperson said:if the fan cant turn on without the heater being on wont a regular normally open single pole relay work?
