We have heard about how an earth is a one large sink conductor whose potential doesn't change no matter how much current is sink into it. Let's say I have a small single phase transformer, the secondary of transformer neutral is grounded and I hook up a bulb 100 meters out. I'm only running 2 wires from line and N from transformer to a bulb. I go touch the hot lead at the bulb, will I get shock or not? Note in above example, I haven't run any ground wire or there is no bonding.
We know in order to get shock, there has to be return path to source though person's body.
If I get a shock, that means the current must flow through the ground to it's source(transformer neutral terminal which is also grounded)
