How far do you go with a Home Inspection laundry list?
EVERY HI report I have ever seen lists MOLD as a problem.
Yup, including mine. Though in my case, it was black mold (the nasty kind) in the attic (where nobody ever goes). So of course it gets written up, but what wasn't written up was the reason for it... bathroom exhaust fans venting into the attic rather than a roof vent. What's the point of writing about the symptom if you don't bother mentioning the cause...
Is listing the cause part of what's required as part of their standard operating procedure? The HI's call out what they see and recommend further investigation by a professional.
In most cases this is probably correct, but in my case both the roofer and mold remediation owners said the HI should have put two and two together and at least mentioned that the bathroom fans weren't ducted.
That seems like low hanging fruit. Not much of an excuse for missing that.
How do you know that it was "black mold"? I have to ask as I had to deal with a lot of mold complaints in my office.
I had to learn a lot about mold.
From what I learned, mold has to be tested to determine the type.
Case in point, I received a call from a citizen, "I have black death mold".
I asked how she knew. She replied "Because it's black"
Disclaimer, I am NOT doubting you. Just curious.
Ron
All things that cannot be inspected by the AHJ in their final since they cannot remove the panel cover.
Inspectors can, and do open panel covers. I don't know why you say that. That's just not correct. How do you think they confirm things like OCPD being correct for the conductor size, or confirm AFCI, or GFCI is installed, grounding/bonding, etc.
HI had a swab sent in for testing. IIRC there were several others of the "mostly harmless" type detected as well, which he did say was typical.
Contacted by a Realtor and forwarded an residential inspection report.
- Ungrounded receptacles.
- Kitchen and bath lacking GFCI
- Open junction boxes
- Breaker panel wiring a mess
All things that are relatively easy to fix.
Then I go outside and find that the mast wiring and meter base are only rated for 100 amp.
Load center has a 150 amp main .
Seems like every time I deal with a home inspection there’s something half assed about it .
Confining my comments to the inspection list, I don't see how item 4, "breaker panel wiring a mess" has anything to do with safety or proper operation of the electrical system. This is not an opportunity for someone to give free reign to their OCD tendencies.
Realtors want to check off the box called Home Inspection with little concern if it was a valid inspection,
if the HI was any good at their trade. I think as it is in NM anyway, it's a waste of $$.
There must be a better way. `
Mold is an interesting area of no return. Never it up if your selling a home.
We live with all kinds of mold. It natural. Just put a bowl of water and flour.
In a few hours you'll have the makings of sour dough.
Mold is the most oversold fear in houses. There is no house without mold. Most all harmless to people.
Fine Homebuilding had a great story on this subject a few years ago.
Sourdough is the result of a wild yeast, not mold.
And yes, most homes have mold. Whether it is a problem is not something for an amateur to determine. About all anyone can do is call in a pro to determine if it needs remediation or not.
Uggh, tell me about it. I sold my home a few months ago and the buyer's bank demanded a home inspection. The HI that came also had a mold remediation business. What do you think he found? Somehow, I was told by the buyer's realtor that she was told that all I had to do is clean the floor joists in the basement (where the problem was) with bleach, which I did, and it wouldn't have to be remediated. So that's what I did. The sleezeballs at the bank wouldn't accept that and the HI comes back to look again. I have an infestation! It has to be remediated! So, buyer hires a remediation company who sends a tech by to look at this "disaster". After looking around for a few minutes he asks me where the mold is. I tell him how I washed and scrubbed everything down with a bleach solution. The mold was gone. Tech calls his company, and they say they can't remediate something that isn't there. HI insists he sees it and bank won't give the buyer a mortgage unless it's remediated. So, I say that the only thing to do is "make believe" it's there.
I said to the HI, in front of the buyers, that all houses have mold. He agreed. Then I asked him how come all of them don't automatically require remediation? He replies "it depends on who is doing the looking".
As it turns out the "mold" was really just mildew, white and powdery that brushed right off that cost $3500 to say isn't there.
My head hurts but not from mold.
-Hal
The entire mold thing is completely overblown. I blame YouTube, every 2 minutes there's a new video about how bad the toxic environment you live in actually is. Mold isn't the problem it's the poisoning of people's minds that's the problem.
Often confused because of the yeasts appear moldy when aging. Similar in nature. Mushrooms too.
You write up a full inspection report, including every thing you find that is substandard or out of code and provide an estimate to repair or upgrade each item. CYA
...including every thing you find that is substandard or out of code...
Which code do you use to decide something is substandard?
It should be the code in effect for the original installation or any local code or insurance requirement for the sale of a property. Any other code is simply your personal wish list.
You also need to leave your ideas of workmanship and substandard installation out of your reports. just because you wouldn't do it that way doesn't make the work wrong.
Now that's just dumb. What's to say someone didn't double tap a breaker not approved for it, or wire nut fifteen wires cut too short, or.....
I agree. What dope would make a regulation that says someone inspecting something cannot open it and look inside? If that's the case then they should require that someone is there during the inspection to open things up.
