aelectricalman
- KY
So, in past conversations I have mentioned a particular drive system which was at 4160V having exploded due to harmonic issues inflicted on the system from a utility source. The capacitors in the drive unit for this 2000 HP drive ruptured (through routine maintenance) and the debris was sucked through the system by a line side vent fan. The result was the transformers, capacitors and for that matter, the building, burned.
The old Harmony Robicon VAC drive was replaced with a Toshiba T300MVI system. This new system operates using diode rectifiers and eliminates the capacitors.
The harmonic source that is affecting the system in only elevated outside of IEEE 519-2014, on the 5th order (6-8% average) and 7th order (3-5% average).
My question is, understanding that this could destroy a capacitor arrangement if a parallel resonance exists...
what can happen to the new type of system. How tolerant are diode rectification techniques in drive systems? Should I worry? Also, are traditional remedies (reactors) the best way to mitigate harmonics for this type of drive system?
Thanks for your help, as always.
