I believe it has to something to do with parallel transmission. 8 wires equals 8 bits ot transmision, or a "byte" at a time. 4 wires equals 4 bits, a "nibble".
This is actually very simple to do. You use 2 of the 4 pairs for data and 1 of the remaining pair for the phone.
Too bad you treated me like dirt in previous posts. We coulda worked together and you coulda billed for like you were a professional. Good Luck
:smile: Since it worked previously and the just suddenly quit then it is a shame the computer guy sent you off on the hunt for a cable fault. Even though using 2 pair for data and 1 pair for voice will work it is still considered rigging and not recommended.
If you find out later the problem to be a network card I like to know.
Real tough area to get lines into, it took 13 man-hours to run the two lines.
That's probably because you did it legally and neatly.or were you just watching?
If both ends are terminated T-568A, the cable is straight thru.Well after running two new Cat 5E cables, one for the phone and one for the data both ends punched down B and my tester confirmed that my office got a message that we have to go back and "punch it down straight through".
If both ends are terminated T-568B, the cable is straight thru.
If one end is T-568A and the other end is T-568B, then it is a crossover cable.
There is no switching with the DC power; phones (POTS) have upwards of 100VAC ringing which couples into the data wiring. The phone DC ("battery" of about 48V) and talking AC (POTS) didn't bother it in the applications I saw. My oscilloscope on the Ethernet lines showed nothing when the phone answered, but did show the ringing signal crosstalk.Could you explain the rigging and why it is not recommended? why would POE be different than using extra pairs for phone?
