- New Jersey
- Journeyman Electrician
I would drill 2-1" holes minimum of 2" apart in the center of the 2x6 and run 6 cables in each. If you have to install draft stop or fire caulk then 3-3/4" holes with 4 cables in each or you might be able to run 14/3's and use only two holes with 3 cables in each.
