dennislewis2001
i need to find this in the nec 2008 "WHERE?"
Please look at George's Post #5 above, click the link to the FAQ, and read it.13 total @ 180watts per receptacle 220.14 (I)
Actually, it is VA and not W, small difference but a difference nevertheless. Your answer is correct unless it is for a dwelling and then the number is unlimited. :smile:13 total @ 180watts per receptacle 220.14 (I)
I think you also need to reread that particular FAQ again. The answer "13" is not necessarily correct, as a case can be made that the receptacle count per circuit in commercial is also unlimited. This is discussed in the threads cited by the FAQ.Your answer is correct unless it is for a dwelling unit . . . .
