Hello.
For my head in a potential job layout.
There is a large old house which is part dwelling (a family) and offices.
Because of certain circumstances, I'm thinking about bringing a separate service drop/ meter/ to this building, and abandon the current service.
I'm thinking 200 amp single phase. (I may also be considering a 3 phase 4 wire delta which is available, depending on single phase 240v loads they may exist at this building).
If you were to install a trough after the meter to feed/tap to 2 main breaker panels (or even 3), what size panels would you install?
20 something yrs. ago, I installed a 200 amp (single phase 3w) service for a 3 family house. I put a trough then tapped to 3 - 100 amp meter pans (may have been 4....was a long time ago) each having a 100 amp mb after the meter.
From reading at that time, I believe I could have installed (taped off to) 6 - 200 amp meters and mb's.
The inspector at the time agreed, but wanted me to change the 3 (or 4) - 100 amp mb to 60's..... which I did.
So..... how many panels would you tap off of one 200 amp single phase drop?
I will read up on it, but just throwing it out there.
Thank you
Thank you
