junkhound
- Renton, WA
- EE, power electronics specialty
new one on me, an internet friend asked me tht question:
My response follows, any others?
ans:
'brown' typically a current indicator, not watts.
as in: How do you know a 3 phase system has high harmonics? ans: "the white wire has turned brown"
Probably not what you were asking, so what was the context you saw the term 'brown' used in?
Resistor code: brown = x10 or value of 1 , black is zero, the other colors are per Roy G Biv, the famous naming specialist, one of Newton's consultants on light.
Or did you see the term in regards to an arc flash event, as in a 'brown pants' event?
then there is the obvious 'brownout', meaning the watts capability of the utility is lacking, so distribution voltage dropped to lessen overall load., but assume you knew that one.
ans:
