The wire needed for a room is more nearly proportional to the room perimeter, 2 x (L+W) than the room area, LxW.
The other distances are for the wire to get from the load center to each room, which involves running the wire vertically [e.g., from a load center in an unfinished basement], then horizontally, then vertically, etc..
So for a 2000 SF house with 7 ea. 10 x 12 rooms, 4 ea. 16 x 16, 3 ea. 5 x 8 [I neglect closets] the room perimeters total to 3968' and the area to 1984 SF, call it 2000 SF.
For a two story house having a footprint of 25' north/south x 40' east/west and 10 CBs supplying these 14 rooms, imagine running wires up to each room. For a center room I can imagine going up 6', going east 20' and north 10' or so, for 36' length.
For a rough estimate use 14 x 36 = 504', and so 504 + 3968 = 4500'.
Otherwise mentally layout the wiring for each of the 14 rooms.
This seems high based on the other posts. Where are my faulty assumptions?
These sizes can go up or down depending on the size of the spools and of the relative penalties for getting too much or too little wire.
