ssandoval
- League City,TX
I have this issue come up on every new project; I can not see how an ETS wired into a fixture can work with a BAS. The wiring diagrams are fairly straightforward. It must have a constant hot, but it can simultaneously be switched. The argument I am having with the EC is that if the "constant hot" is routed through/ controlled by the BAS then it is no longer a constant hot. When the normal power circuit is shutdown at night by the BAS, the ETS senses a power loss and it transfers to the EM circuit, which is not hot because the main ATS is in normal power mode because there has been no loss of utility power. So, all of the EM lights and their LED's go off at night. With this in mind, I can't think of any reason (other than shortened life expectancy from overuse, which is definitely worth consideration) why it will not work this way, and our district no longer requires "night lights" in corridors and classrooms. However, in my opinion, the only way around this is to run a constant (normal power) hot to the ETS, by-passing the BAS, and then run the BAS-controlled circuit to the ETS for the "switched" power source. The object is to be able to shut off all of the lighting in the bldg. at night for energy conservation. In order to accomplish this, am I correct in assuming that a "constant hot" non-BAS controlled circuit will now have to be run to EVERY emegency light?
Any thoughts or suggestions would be appreciated.
