J.P.
- United States
I haven't messed with gate openers, garage doors much beyond supplying power. I was leaving a job recently and the fence/gate installer was out by the gate. I stopped and asked if he need the breaker turned on.
It turned out that he needed his keypad wired and programmed and the batteries hooked up and a gate loop put in. I had to set the gate limits and the remotes as well.
I had no clue and still don't have much of a clue about the gate loop. I thought it was a pre-made part that just got wired in to the operator.
In this case it was some #12 THHN....
I read a few differing opinions on installation. The boss's opinion is what counts though, he seemed pretty vague on details. But I still am curious.
Does the wire have to be twisted?
I have seen a few diagrams where they take a single strand from the operator make 3 turns around there trench or cut and head back to the operator. The only twisting was where the lead in wires were just to keep them neat.
The method I used was to make 100ft of twisted wire at 6 twist per foot and loop that around the trench once.
Could I have put it in pvc? Would it even work through pvc?
Would 12/2 urd work for this or is the separation of the wire inside the insulation to great?
I didn't get to test the loop because the loop detector module wasn't even ordered. I would really have liked to try out both methods before covering up the wire.
