How to calculte Automatic transfer swicth ampacity based on the NEC
If the EMDB main breaker i.e ( 1600AT/2000AF) shall i use the ampere frame value as ATS AMP rating?
No need to do that. The size is based on the loads you are going to connect. If you are connecting all of the loads to the 1600 amp OCPD, then a 1600 amp ATS is fine.
This may be a little off subject but I just noticed the picture by your name is of a High Voltage Arc Flash.
I always thought it was a Red Bud tree just like the one I have in front my yard. :p
JAP>
