No need to do that. The size is based on the loads you are going to connect. If you are connecting all of the loads to the 1600 amp OCPD, then a 1600 amp ATS is fine.If the EMDB main breaker i.e ( 1600AT/2000AF) shall i use the ampere frame value as ATS AMP rating?
