Scheffler Energy
- Minnesota USA
- Master Electrician
Hello,
I am trying to figure out the best solution to a customers problem. We want to mount 3 services on a wood backer board. I want to mount 1 meter 320 millbank meter and triple lug out of the load side to a solar service , 200 amp service for a future shed and 200 amp service panel at the backer board. So I would have two 200 amp disconnects and one 200 amp panel at the backer board. My problem is that mill bank doesn’t UL any of the meters to be triple lug even when they make a triple lug ! I need to figure out a utility / UL / AHJ compliance to have 3 services on one meter or I could do two meters maybe I could mount a tap box with lugs before the service panel on the board and go from there to the solar disconnect and from the tap box to the 200 amp panel on the backer board. Milbank will only allow a double lug on the load side of there meter. Any suggestions or strategies is much appreciated ! 2023 NEC Minnesota
