How to cut in a 50A receptacle?
The gangable boxes have clips (ears) that will prevent the box from falling in. You don't have to attach it to a stud if you use a pair of Madison straps.
I understand that the box has ears however I have also seen boxes with ears get push thru the sheetrock. Madison clips are really there to keep the box from coming out not from going in
I haven't had any complaints with the several 50 amp outlets that I've installed that way. I guess I just cut them in tighter and the customers have had no problems.
In a place like a range you may be able to do it but if you are plugging in and unplugging I can't imagine it works. No matter I would not install it that way, I would want a stud to fastened the box.
Fastening the box to a stud is certainly the best practice. The OP was looking for viable options.
I agree with that statement.
It sounds like most of us have a "grip" on what has to done to install this device even with our varying opinions.
There are many variables to stage how we execute the job and we could all learn from them.
I have installed old work boxes and spray foamed them in place in certain applications.
Like a welder that gets put away and then taken off the shelf to use. They only need a 30 amp circuit or less, but come with 50 amp plugs. Same with small plasma cutters.
