Thanks for your advice...Currently I'm doing the hands on calculation, have not using the software yet. For my own calculation, I all use PU...
So for the wye wye connection transformer with neutral to ground resistor on secondary side, how can I find its zero sequence impedance? Pls advice...
BTW, could you please also advice how to find the postive-, negative- and zero sequence impedance of the generator(Wye connection without neutral to ground resistor)?  Thanks
