Electrician pointed in the general direction of the water pipe and the helper was unclear on the concept?
Need to see the service to see what's going on. From your picture I agree with the missed the water pipe by that much, 99!
Is that raceway still bonded if you remove the bonding jumper in question?
May not be a grounding electrode but instead a bonding jumper for equipment grounding purposes.
May still need additional grounding electrode ran if there is none already.
Answered my questions I guess.It's simply a bare ground from the panel to the conduit. The raceway goes directly to the panel. This is merely a redundant ground path. Does not attach to anything going to water pipe or electrode. I relocated it about 6" to the cold water pipe and verified the jumper at the meter.
