Texas Wires
- Texas
- Electrician
IMG 20240823 170823903 HDR — Postimages
So I see the 2 hot wire, and I'm assuming 1 neutral wire coming down. No ground wire from down ?
Then 1 large bare wire coming from bottom assuming that is ground coming up and bonding to neutral from top? . If I'm trying to hook a normal 3 wire circuit into here what do I do. I'm thinking won't it be bad to hook the white and green both to that one bar? I thought add a ground bar....but if ground and neutral are bonded here that changes nothing right?
