StarCat
Industrial Engineering Tech
- Moab, UT USA
- Imdustrial Engineering Technician - HVACR Electrical and Mechanical Systems
Clarification on Heat Pump Theory
Typical standard " old school " electric heat pumps operate as thus:
The condensing unit supplies heat down to what was once known as the balance point, below which the aux. heat is supposed to take over all heat demand based on outdoor air temperature lock out. This is due to efficiency loss of the condensing unit below the balance point for " air source " heat pumps.
If " EMERGENCY heat is selected on the Thermostat control. The Condensing unit is fully locked out.
The Condensing unit and the aux. heat BOTH run when the out door unit is defrosting.
I was certified as a Heat Pump Technician by RSES international in 1992 and have worked on many different types.
They can be useful in residential settings when installed well. Within commercial settings they almost always become a service liability wich totally overruns the perceived energy savings.
Sincerely
Sincerely
