ArkLightning
- Nebraska
- Stud
Howdy folks,
Question about string size. So we're finally ready to pull the trigger on a solar array + storage. Settled on the Sol Ark 15K which has (3) MPPT inputs and max DC input of 19.5KW directly connected. Our utility allows maximum nameplate array of 25KW. System will be ground mount, no shade issues. Hybrid grid tied.
I was looking to use 450W 72 cell panel (Risen RSM144-7-450M for sake of argument) and running 13 in series or 5.85KW per MPPT. VoC is 46.43 and adjusted for our climate for the coldest day of the year (x 1.13) makes the math 52 VoC x 13 panels = 676V. Sol Ark has a limit of 500V so no bueno. Question is if I use a DC-DC optimizer, such as a Tigo TS4-xx-xx does this magically adjust voltage to =<500V? Is this is preferred method or less than ideal design? Is there programming on the Tigo to hard limit voltage to 500V or does the inverter communicate with the optimizers?
The remaining KW available (we want as close to 25KW solar array as possible) will be AC coupled and waiting for the Sol Ark micro inverters to hit the market Q1 '23. I would prefer a single inverter solution (mainly for cost reasons). Am I thinking right or myopic in my design? I also understand genny may not be supported when AC coupled but that's another topic for another day...
Battery wise I'm not 100%. Right now the SoK looks great on paper. Lithium Iron Phosphate seems to be the way to go and they certainly hit a nice price point.
Thanks in advanced
Thanks in advanced
