ITO said:You have to be proactive here and produce a clear scope. You can do this on a job like this by drawing a set of ?shop drawings?. Basically you need to draw some electrical plans? maybe that was not in your bid but it?s too late now so call it damage control and learn the lesson. Then ask the owner to approve your drawings in writing. If this involves an lengthy walkthrough with said shop drawings in hand then bite the bullet and do it, having a clear scope is worth it.
The approved shop drawings will be your base, if they make changes in the future you may be able to get paid for them and being able to show how it was a change in scope will help. If they complain about work that has been installed you have the approved shop drawings to fall back on.
Anything done without approved drawings of some kind, is subject to change and is hard to get paid for.
As a bonus when the job is over, you turn over a copy of your shop drawings as as-builts and you look like a pro.
Good luck.
360Youth said:We tried to bid high end all the way around, but it was assuming there was going to be some sort of electrical plans eventually.
Not only hard but at times impossible and you will have little recourse.I added extra cable and phone jacks to a new house and when I billed for it the HO did not want to pay claiming they asked to have existing outlets moved and not more outlets added.I had nothing in writing to show they had approved the additional work it was an expensive lesson I learned earlyITO said:Anything done without approved drawings of some kind, is subject to change and is hard to get paid for.
Good luck.
my biggest concern is dumping changes orders and unexpected extras on him that the HO.
220/221 said:Well, there's your problem right there
You said it was a 9K sq ft house?
How big is YOUR house?
Your biggest concern should be how much money you can earn by providing them with a top notch electrical and lighting system.
220/221 said:How did you bid it without a print?
I would have bid it high and spent whatever time was necessary to get everything laid out right.
Tiger Electrical said:If I don't have a set of plans I just quantify the job...so many duplexes, so many SP switches, so many 3ways, dimmers, lights, etc. At the end it's easy to see if the quantities are the same. I still do COs if the quantities change by more than a little.
Dave
