I had a problem with a out side light pole that was blinking on and off every 20 seconds or so. The ballast said that the lamp should be a high pressure sodium 70watt. The owner had put in a 35watt lamp. I put the 70 in and it worked fine. Why can't the fixture take a lower wattage?
