tonype
- New Jersey
My guess is that they used it as a chase to get power to an upper floor. You might find a similar setup where the pipe enters the attic from below.
Is it safe to conclude that this does not meet NEC?
Somebody took the words "shall be arranged to drain" very seriously:lol:
There is no way that this is code compliant. For one thing you've destroyed the integrity of the sewer line. Secondly if the sewer pipe became clogged below this point the sewage would back up and come out of the conduit body creating not only a mess but a potential health hazard.
Which could still happen to an actual drain pipe tapped to the same point should there be a clog.
Level switches?:?
Although this is an old cast iron pipe the entire system is supposed to be watertight. A good plumbing inspection would require you to cap off all outlets and fill the entire system with water by inserting a hose in the top of the vent on the roof. There should be no leaks.
I thought something like that, too. Level or flow switches or sensors of some sort.
