james2012
New member
- Ashburn, VA
I am installing an Aprilaire 800 humidifier.
The product allows for a range of input power.
I would like to use the highest setting, which is 240v @ 16amps
I would expect a dedicated circuit of 12 gauge wire on a 20amp breaker to be fine for this 16 amp continuous load, but the installation manual calls for 10 gauge wire and 25amp breaker.
Is it safe to install this to run at 16amps on my 12/20 wire/breaker? Or do i have to run it at the lower setting, of 11amps, as the manual states?
