Can you hear it? Or if you haven't been there to check, do you know what is in and around her house (beside the runway)? Here's why.
"Humming" is vibration. For "EMF in the wiring" to cause detectible vibration in a residential structure, the energy would have to be so incredibly powerful that the wiring would not contain it, the house would be a small pile of ashes. So right off the bat, don't go down that road.
Most likely there is a transformer somewhere near her, and it is either new (to her) or beginning to fail. Another possibility could be a failing solenoid coil on something that runs continuously in her house (that's why I asked if you knew everything that is in there), but usually that ends up being more localized and can be traced by moving around to where it gets louder. If the entire house is "humming", then it's likely something coming up from the ground.
To give you an example, I have a PoCo sub station about a block away from me on the other side of a creek, with a road and a park between us. About twice a year, the soil conditions are just right to where I can hear the transformer hum coming up through the floor, 24/7. It typically lasts for a few days at most, once it lasted for a month. But once it rains or it dries out and the soil conditions change beyond the narrowly specific conditions it took to conduct those vibrations, it ceases. So in her case, let's say the airport has some taxiway lighting installed, which has constant current transformers for them, usually in underground vaults. it might be that something has changed recently which allows the vibration from the nearest transformer to transmit its mechanical harmonic under her house. it might also be that it has always been there and the transformer is getting old, so it is noticeable now.
Bottom line, look for real tangible causes, don't buy into the hype that surrounds most "EMF hypersensitivity" claims.
