alfiesauce
access to an infrared camera might be useful too.
220/221 said:You are not suggesting putting your ear on a paper towel roll and putting it on a live 450A fuse are you? I would be hesitant even to open the cover.
I've heard that noise can turn into arc flash pretty quick. It's like "What's that noi......"
There you go substituting words again!zog said:You are comparing apples to oranges. You want a FOP calculator? Try Ohms Law.
wptski said:There you go substituting words again!This is "FOP" vs "Voltage Drop" or proper word using of.
Not sure who coined "FOP" but there just isn't any other reference to where it's used except soil resistance testing. I'd guess that a simple voltage drop test goes back farther in time than a Fall of Potential Test does.
roger said:Whatever happened to thinking out side of something said in a book?![]()
Roger
Beats me. Maybe you secretly like me? Sounds like the other guy has his mind made up, so there's not much point in beating my head against the wall with him.zog said:And why am I defending you marc? Come on step up.
I've seen other times here where the use of terms is brought up, so I'm mentioning it. FOP been used by others before and I wonder why are they using that term instead of the common term "voltage drop".mxslick said:Well put.
That is a common malady in my business..many folks are so used to traditional cinemas that a screening room throws them off.
As for the others having issues with terminology: Chill out, guys. It's just a discussion on a forum..why does it have to break into a catfight?![]()
We all come from different backgrounds and experiences, both personally and professionally. Accept that and move on.
Read what's written here with an open mind, and take the words in context, not what words are said.![]()
augie47 said:o.k., 27 posts and nobody has asked..... unbelievable...
what tune is it humming ?
augie47 said:o.k., 27 posts and nobody has asked..... unbelievable...:grin:
FOP method is a induced current flow to find a unknown resistance like a Wheatstone bridge or 3/4 point soil resistance testing. If you do a search on "FOP", you'll find where it's commonly used and it's not in this situation.mxslick said:Cool Bill, that explains a lot.I can see where the confusion is coming from.
I think the difference is that while FOP and voltage drop can in one context be used to describe the same thing, i.e. a "fall of potential" can be described as a voltage drop, and a voltage drop can be described a a "fall of potential."
In my own experience, the usage would be as follows:
"Fall of Potential" describes the test method, i.e. reading the voltage across a fuse as in this case, or between the line and load sides of a circuit breaker.
"Voltage drop" would be the value, in volts, of difference between the reading at "point A" and "point B".
All a matter of experiences aand who is describing the event.
"Ready To Explode" by that acid rock band ..never mind this is a family forum.![]()
