IEC 60287-1-1 provides ampacity calculation methods for HV cables, these methods provide the ampacity for single conductor cables. What would be the total 3-phase ampacity of the whole circuit? For example, if the calculations show that Phase A has 500 A, phase B has 500 A, and phase C has 500 A; then what would be the total ampacity of the 3 phase circuit? Thanks for help!
Terminology is very important here. Often the phases refer to the line-to-line currents in a load at the line-to-line load(s). So: AB, BC and AC
The three wires, A, B, and C, are called the phase conductors.
But sometimes people instead refer to the A, B, and C phases.
Trying to answer your question in a way that is independent of the choice of terminology, if the three phase circuit is capable of 500A on each of the three conductors, it is called a 500A circuit, and would be protected by a single three pole 500A breaker or three individual 500A fuses and a phase loss detector, if needed.
Using the terminology "current per phase" and "total current over all three phases" is sure to cause confusion.
