HV Grounding(15kV systems)URGENT!!!!
bennie
Esteemed Member
Re: HV Grounding(15kV systems)URGENT!!!!
Give more details...Type and size of cable? MGN or ungrounded secondary supply?
Contact a customer service engineer at the local utility. Also call the nearest IBEW lineman local, for companies experienced in medium voltage installations.
rey-man
New york
its 1/c, 4/0, EPR insulated, 15kV, installed triplexed.
thanks for the help.
bennie
Esteemed Member
The insulation is ethylene propylene rubber (EPR) Do the single cables have a concentric neutral around the insulation jacket?
rey-man
New york
you mean the copper shielding tape???
which neutral are you referring to?
gwz2
Indiana
For starter(s), see:
250 Part X.
250.180 " - - - shall comply with all applicable
provisions of preceeding sections of this article and with 250.182 through 250.190, - - -"
250 Part I & up.
250.4
250.134, especially 250.134(B).
250.122.
Some cables just have a minimum (size) of shielding which is nothing more than a static drain wire.
Others have an (equivalent) 1/3rd size of the phase conductor, so that grounding conductors on 3 of the phase Conductors equals a full size grounded conductor when terminated at each end of the cable run.
The above description is basic only.
Consult the cable manufacturer by e-mail.
[ June 11, 2003, 03:15 PM: Message edited by: gwz2 ]
bennie
Esteemed Member
The highest distribution system voltage is 34.5 KV. This system uses cable with a concentric neutral.
Three phase loads the neutral is 1/3 size. Single phase loads the neutral is full size.
bennie
Esteemed Member
To get back to your original question...The ground wire only needs to be #6 cu. to a rod or butt plate.
