HVAC calcs
alixenos
Florida
Electrical Design Engineer
Hello,
I'm trying to learn how to size conductors for different HVAC equipment and I'm confused as to what to use as far as the following:
1- MCA/MFA = 1.9/15 @ 208/1phase/60 HZ. What current should be used to calculate the KVA? and what should be used to size the conductor?
2- MCA/MOCP = 58/70 @ 208/3phase/60HZ. what current should be used to calculate the KVA? and what should be used to size the conductor?
3- FLA/MCA/MOCP = 2.4/20,37/25 @ 208/3phase/60HZ. same question as above.
4- RLA/MCA/MOCP = 7.1/9/15 @ 208/3phase/60HZ. same question as above.
Thank you so much.
The MCA is fairly useless because it has 125% added to the largest load unless there is only a single load then you can multiply by .8. IMO you should use the provided FLA and RLA.
+ you use the MCA to size the conductor and MAX to size the largest over current device allowed
For conductors/OCPD for a single HVAC unit, you just need the MCA and MOCP. [MFA = Max Fuse Allowable? Same idea as MOCP.] The conductors needs to have an ampacity of at least MCA. The OCPD needs to me no more than MOCP. The load in VA is based on MCA: MCA * V for 2-wire motors, MCA * VL-L * sqrt(3) for 3-wire 3 phase motors.
Once you have conductors supplying multiple motors or HVAC units, you need to "unpack" how MCA and MOCP are calculated. MCA for a single unit is 125% * the largest motor's FLA (or RLA for compressors) plus 100% of all the other loads. MOCP is MCA + another 125% * largest FLA/RLA, rounded down to a standard breaker size. [Equivalently, the MCA formula with 250% replacing 125%, then rounded down.]
The point is that with multiple pieces of equipment, you still only include the 125% (or 250% for MOCP) of the single largest FLA/RLA supplied. So let's take a feeder that supplies just two of your #4 units. 125% * RLA = 8.9A, so there's 0.1A of other loads for an MCA of 9.0. And 250% * RLA = 17.8A, which rounds down to 15A.
So for two of the units, the computations are MCA = 125% * 7.1 + 7.1 + 0.1 + 0.1 = 16.2A. And the MOCP is 250% * 7.1 + 7.1 + 0.1 + 0.1 = 25.2A, rounded down to 25A OCP.
Once you have this combined MCA calculation, the load in VA is calculated the same as for a single unit. Although I guess the discussion so far has been for all motors single phase or all motors 3 phase; some further thought would be required for the case of some 3 phase motors and some single phase motors.
[I'm using HVAC and motor interchangeably here, as for motor driven HVAC equipment, the only difference in the formulas is that a motor driving a compressor may have an RLA rating (rated load amps) instead of a FLA (full load amps) rating.]
Cheers, Wayne
Cheers, Wayne
Thank you very, very much. this is very helpful.
