HVAC disco
websparky
Cleveland, Ohio
First time I have seen one of these!
Re: HVAC disco
A three pole disconnect with no locknut on the conduit stub out?
I'm guessing you're referring to the switched EGC?
Re: HVAC disco
Some 1 phase elevators use a 3 pole diconect the GC on one pole it has something to do with keepin emergencey power off with the disco off
Re: HVAC disco
Well first off, the EGC needs to be bonded to the enclosure. But, that's easy.
OK, here is a clue:
This is for a typical air conditioning condernser unit. This could be allowed for other types of equipment but usually not condensing units.
Does this help?
Re: HVAC disco
Did you exspect to find fuses? Just guessing. :confused:
FWIW, I know you said that the Green is the EGC, but I have seen lots of old installations that used Green as an ungrounded conductor.
