I have been trouble shooting a 120V 20A GFI outlet used for a Doctors office. He has a hydroculator plugged into it. This machine is filled with water that is kept warm so the towels used for physical therapy are always hot.
After several visits trying to figure out why it keeps tripping the GFI outlet I told the Dr to have the unit serviced. He did and they said nothing is wrong with the unit. I then rewired the dedicated circuit and installed a new breaker and GFI outlet. It held for a month then tripped the outlet again. I have the same setup in 3 of his other offices with no problems so I suggested to him we swap one of the other office units with this one. The new hydroculator tripped the outlet again.
Two questions here for the forum,
1. can an Xray machine cause interference? it's about 50 feet away down the hall.
2. Does the hydroculator, it has a corded plug, require a GFI outlet? We installed it this way because the appliance requires the employee to put their hands in water to retrieve the towels.
Any suggestions
Any suggestions
