I find it hard to believe that some say there is no room to locate a blank face GFCI somewhere in the bathroom? do some have the thinking that it is against code to locate it near the tub?
A hydro massage tub is not a pool or hot tub, it is just a tub that has a pump, the same rules apply to it that apply to a standard tub or shower with just a couple other things thrown in like bonding, it just can not be located within the tub space which is the same requirement of a standard tub.
We are only required to follow Part VII of 680 which is 680.70 through 680.74 the rest of 680 does not apply as it clearly states in 680.70, 680 72 will direct you to follow the requirements of Chapters 1 through 4 in covering
the installation of equipment in bathrooms and that is all there is to it.
680.71 only requires that if a receptacle is within 6' it has to be GFCI protected, which 210.8 with require any receptacle in a bathroom to be GFCI protected, but the NEC had to cover where these tubs might be located in other locations like I have seen them in bedrooms kind of like a poor mans hot tub.
As Dennis has pointed out it is about half the cost using a blank face GFCI then using a breaker and you give the customer the convince of having it in the same location which is how I like to install all GFCI's, another point is they are UL listed as switch rated for motor loads and home owners can use them to keep the kids from playing with the air switch in the tub if they don't want the kids to us it, I rarely use GFCI breakers anymore, and I do not like to down load receptacles off a GFCI that are in other rooms even when they are fed by the same circuit, as I do not like service calls of a receptacle not working just to find it was fed by a GFCI receptacle located in another room, kind of an awkward position of charging the home owner for resetting it. at least if I didn't do the install I can offer the homeowner the choice of redoing it so it doesn't happen again. nothing like searching for a GFCI somewhere in the circuit then dealing with the home owner as to why I had to charge 2 or 3 hours service call to find it and reset it.
I like Dennis thinking on this.
