I have a customer who wants some wall thermostats installed. The type of heat being controlled is boiler heated water thru PVC tubing.
He commented that I could place the stats wherever I thought they would be the most effective.
He said that there wasn't any type of sensor installed prior to the concrete pour.
Will a stat without a sensing probe in the slab effectively control the temperature?
Not familiar with this type of work.
Thanks
Hot Water Reset
https://en.wikipedia.org/wiki/Hot_water_reset
Infloor heat in the slab, you are in contact with the radiator at all times. Most common complaint is it is too hot, even with fixed temp mixing valves.
A reset control measures the outside air temp and sets the distribution system mixed water temp linearly with OAT. The infloor loop water temp would vary in the range ~ 90 to 130 F with the reset system while the room stat only calls the circ or zone valve (on/off).
Depends on the boiler. Modern condensing modulating fire gas boilers have hot water reset controls built in. Old style non condensing boilers run at 180 F on the boiler aquastat and would have to have the reset control added on the secondary distribution loop to vary the distribution loop temp with OAT. Necessary and expensive to add if it's not there now.
A standard boiler I would set up for primary secondary pumping with a Tekmar 361 to reset the secondary loop temp. This by itself can run in auto with almost nothing for room stat control.
http://tekmarcontrols.com/products/hvac-systems/361.html
You can mix with either a three way valve or variable speed injection pump
http://tekmarcontrols.com/support/tekmarglossary/33-support/glossary/193-variable-speed-output.html
If he's running straight boiler temp water to the in slab radiant loop, that would sound like trouble. If the boiler water is already mixed down to the distribution loop temp using OAT reset, that's about 90% of the work necessary, and any room stat calling the circ or zone valve will do. Tekmat makes combined space and slab temp sensing stats, but without OAT reset of the loop water temp the job could prove unsatisfactory.
http://tekmarcontrols.com/support/tekmarglossary/33-support/glossary/84-outdoor-reset.html
http://tekmarcontrols.com/solutions/browsesolutions/radiant.html
