mark32
- Currently in NJ
Let's say you are wiring a large dwelling and would like to install two 200a panels, one at the service and another on the other side of the house. Tell me if you like the following setup. From the ct meter you go underground and (Back of meter would place it a number of feet below the grade in the garage) enter a 400a disconnect (All GEC's would terminate here) mounted in the adjacent garage, you then nipple into a metallic trough mounted below it. Out of the top of the trough you nipple into a MLO 200a panel, out of the back of trough you enter with 4/0 AL ser which runs to the other 200a panel 75' away. In the trough you splice the conductors using those insulated taps and bolt an uninsulated distribution block to the trough for the EGC's. Sound good?
