iceworm
Curmudgeon still using printed IEEE Color Books
- North of the 65 parallel
- EE (Field - as little design as possible)
Holy Faraday Batman. All these years we have been thinking transformers followed Faraday's Law and required a changing magnetic field. Now we find out that if we left the Batmobile key on, the coil will put out 10KV DC continuous. I'll call IEEE and have them start rewriting all the papers.I beg to differ with you.
Ignition coils are DC transformers. The primary and secondary both have polarity. They can also tolerate the rated DC voltage indefinitely. Like when someone leaves the key on an older vehicle while the points are closed. ....
(Just screwing with you - I know you didn't say that)
K8 - I didn't think that interupted DC and kettering ignition systems have much to do with the discussion. But, that's okay - I'm good. And you did get the part right about how the spark happens when the points open. And your comment brings up a good point about the doorbell xfm when energized with DC could put up a good spark (on the primary side) when the circuit opens.
So, physics questions for the day.
How come there is no spark when the points close?
As for the polarity wearing out the plugs - How do waste spark systems work?
Been maybe 40 years since I have goofed with a Kettering ignition. Good memories though. I remember my brother and I using a Lionel train transformer to drive an ignition coil and making a jacobs ladder. I'm not clear on why we didn't kill ourselves - or burn the garage down.
ice
