peter d
- New England
I have just finished a working in an area where inspectors operate with impunity, and I am glad to be getting out of there soon.
I have ranted about this in the past in one of the many "fan box" threads, but it goes much beyond that.
In this place, inspectors make up their own rules, contractors follow them, and they are rarely challenged. If you do try to challenge them, they will use "the system" to make your life miserable.
Some notables:
They require all kitchen recpetacles, not just the counter, to be GFCI protected.
They make you rip out all exsisting romex above suspended ceilings even if you are only adding a few new circuits.
They make you put in fan boxes even where no fan will be installed.
They make you repair other code violations not related to the job you are doing. For instance, even if all you are doing is a service change, they will make you repair any violations that are visible in the basement.
They make you run a ground wire in EMT and other metallic raceways.
They make you install "Firomatic" devices above gas burners even though the code only requires them for oil burners.
There are others but I can't think of them at the moment.
Nice, isn't it???
Some notables:
Nice, isn't it???
