Re: I am angry and I need to rant
Bhp I am not sure if your inspectors use the same correction notice forms that ours do but at the bottom there is a section where the small print is
corrections not made within 15 days may result in penalties from $500.00 up to$5,000.00.
But the kicker is that there is also a section that requires the inspector to haveat least tried to make field contact,at the least at the end of the business day call the contractor before A $ fine is imposed.
Several months ago the chief building inspector had a meeting with all the inspectors telling them of this requirement.Before a $$$ tag was to be issued they at least at the end of the day were to call the contractor that a correction notice had been issued and in order to reibspect they had to contact the EC and inform them of what the viloation was and what was needed to pass
The county had almost 4,000 outstanding permits due to red tag/payable fees,and the chief building inspector told all thier guys to write non fee correcton notices first then charge the applicable fees.
1st tag free
2nd tag $30
3rd tag $60
4th tag $100
5th tag $500 and called before the board
Now I think that is fine.But that lasted all of about 2 weeks.
Then it was back to $30 red tags from jump street.Don`t get me wrong if an EC fails to do thier job then they should be tagged,but when a framer adding window bucking creates a tag issue after the rough in,or fire blocks a wall after walls are built and just pushes our nm out of the wall so they can add said fire blocking,to me this isn`t an nec violation.Maybe poor scheduling,but it is quite ovious who was there first.There are some inspectors that will call and say hey the framers f _ _ _ _ d you and did this or that I`ll give it a non fee green tag,get it taken care of but there are still some that just rip out that $30 tag and only write up 100% reinspect required.So we go and fix the framers changes,maybe we miss the access that was not on the print but is now framed in 6 ft rule BLAM $30 ,Or we miss the med cabinel and Blam $60.
The AHJ having jurisdictiction is nothing but a cash register waiting to get filled
Last year we did over 2,500 homes and this year it looks more like over 3,000 You would think with the work load placed on the inspectors.they would just call ( some do but not most)
On average they roll 10 to 20 inspections a day.You would think they would want to clear thier plate but no lets just add what is rolled to the next 30 they get
So now they hired private engineering firms to help,But they spot check them and fail what has been passed some reasons actually happened.Bending radius where the nm stapled going into a can was pushed up more than they thought it should be,orbox out of wall when it is obvious that insulatters pump edexpandabl foam behind a solid chipped out 4 gang
If it is legit and it violated(our install)
ny all means tag it,Oh the best is when an lv compamy fails to protect thier wire and we get the tag for 800.6 i think it is that relates back t 300.4 D
Somebody draw a line here
