- Windsor, CO NEC: 2017
- Hospital Master Electrician
Reminds me of what happened to my wife when asked her to simply replace some plates for duplex outlets. I don't actually know how she did it but she ended up touching my most excellent Klein screwdriver against the metal box and the line side of the outlet screw....but I can't resist posting these pictures of an ill-fated tape measure from a couple weeks ago. Just pure bad luck on the operator's part...
Once again, just to be clear, there is no right or wrong orientation!
This may wind up closed (I don't begrudge other mods closing this.) Enjoy!![]()
Well, now I learned what will happen if I have the ground up. Why didn't I think of this?:slaphead:
I have to change my habit and start installing the grounds down or use a fiber glass measuring tape.
Either that or only the upper cord was plugged in at the time of the operator failure.Did the tape measure (which was upside down) manage it's way between the two plugs?
Now we know what the voltage drop is for 120V @ 36-1/16"!:lol:
Also, I wonder if the GFCI tripped, or the breaker, or both?
If both, which was first?
Or the "fuse link" with distance markings on it just broke the circuit. They can't handle nearly as much current as a screwdriver can.The GFCI would only trip if the tape measure was grounded/bonded somehow, so I would guess the breaker on a SC fault.
Edit: Could have been the GFCI as the receptacle is mounted in EMT and that would be a bond/ground connection that would cause the GFCI to trip. Had to go back and look at OPs pics to spot that.
If any.
It is very likely nothing tripped.
Why? Serious question here, not being a smart aleck.
It is possible that the tape blew clear. I have seen a quick short that would not trip the breakers. It must be sustained long enough to trip the breaker
Interesting, I had not thought about these points. Thanks.View attachment 8771
I am being serious as well and not trying to be a smart alack.
I see two blasts on the tape that indicate it was a line to line event not a line to ground event.
That being the case the GFCI would be blind to it entirely.
As for the breaker I would say chances are high that the breaker stayed closed as the tape blew out (opened) first.
