Cow
- Eastern Oregon
- Electrician
A single rod could be good enough if it has a low enough resistance... I forget how the code reads but there is a level there that if you read under that, you’d not need a second ground rod. The second rod is to try to get the Ze under the amount needed sofaults will trip the breakers. It is all about Ze and Ze... and breaker trip current amounts.
You're misunderstanding what Infinity and myself are getting at. He has been around for a while, I'm sure he knows when two rods are required and when they are not.
If the service requires a grounding electrode system and takes two rods to get it done, why would an outbuilding requiring a grounding electrode system only need one?
Second, I believe you're mistaken on rods playing a part in the operation of breakers sensing overcurrent conditions.
