readydave8
re member
- Clarkesville, Georgia
- electrician
Painting floor is great idea but has never worked for me, sheetrockers ignore and finish floor usually installed when I come back for trim-out
One doesn't need to be a rocket surgeon or brain scientist to figure it out.
If you continually get buried boxes from a 'waller, drive 16d nails in studs adjacent to each location, leave about 2" exposed. Enough they can't be pulled by hand or easily knocked out. It's not a foolproof method but it will incite a reaction.Painting floor is great idea but has never worked for me, sheetrockers ignore and finish floor usually installed when I come back for trim-out
I thought I had seen everything.........but this at a hydro dam......a cow fell in....takes the biscuit in my experience. The little 400kW turbine was still in operation.......Stopped by a kitchen remodel today to take care of a few small items before the cabinets went up. I know the HO wanted plywood instead of drywall 'just in case the cabinet crew missed a stud".
When my house was being built someone spraypainted a bright pink "6" on the slab in the kitchen, then the builder covered the floor in vinyl. Ten years later the paint finally migrated up through the vinyl. Not knowing where it came from, my wife tried and tried in vain to clean that pink 6 off the floor but it wasn't until we tore up the vinyl that we saw what had happened.Painting floor is great idea but has never worked for me, sheetrockers ignore and finish floor usually installed when I come back for trim-out
An of ounce of prevention is worth a pound of cure: Ben Franklin
And this is my 1000th Mike Holt Post. Do I get a prize?
We can't all be as awesome as you are.
I wonder if he's run into really bad drywallers more than a few times.
This is what I found in my house after I bought it. The water pipe screw had sealed itself. The insulation was damp but not soaked.
Or this:
An oilfield in the Saharah so nobody much around to hear it.That must have made an interesting sound.
