Please help, I need an equation to calculate, in joules, the amount of heat that is created by an electrical test circuit inside a calorimeter.
Note: the circuit's input power supply is a capacitor charged to a certain voltage and discharges with nonlinear voltage and current.Although total joules of input power have been calculated, I suspect this may make future calculations difficult.
Also,a "power under the curve" has been drawn on graph paper showing temperature over time.
The big question is when I count up the squares
how do I convert this data into joules and then use this to calculate the efficiency of the test circuit. Any and all help is welcomed. Thanks Brad
